Dec 21, 2022
07:27 AM
Dec 21, 2022
07:27 AM
Hi ,
Instead of using virtual COM port for PUART I want to connect these pins to extenal UART, which then can be connected to other board. I turned of SW5 to OFF position and connected USB to TTL converter pins as below
TX = P4
RX = P33
5v = 5V_Bus
GND = GND
Before SW5 turn off I verified I am getting trace message on Virtual COM port PUART but after SW5 is OFF I did not
observed any output on terminal.
07:54 PM
Jan 01, 2023
07:54 PM
Hi @pghole ,
If possible, can you please attach the USB traces which you have observed at your end here? Meanwhile, I will check internally for this issue and update here.
Aashita
