umg_4380326
First like received
I need suggestion and a little clarification regarding the central -peripheral example PSoC-4-BLE/100_Projects_in_100_Days/Day012_Central_Peripheral/Central and Peripheral/Central and Per...
I would like to know if there is any  flow chart also how do i put the code in the ble stack handler with respect to events without the commands through COM port.
Implementing the same as in example without the Com port commands.
Uma
Yugandhar
500 solutions authored 1000 replies posted 5 likes given
Hello Uma,
Please refer to the Central and Peripheral.pdf datasheet for more information, where it gives detailed information on firmware flow of the project.
P Yugandhar.
Yugandhar
Hello Uma,
P Yugandhar.
