NIFR_4499596
Welcome! 5 replies posted First question asked
Hi All,
I have a big problem in my PCB project, I need to use 2 SCB components (SPI and I2C) but I make a mistake in choosing their pins and I can only access SPI or I2C in separate projects. The pins I choose are the following and I found out only now I mixed SCB0 and SCB1 pin for SPI and I2C. I would like to know if it exists a solution to solve the problem without soldering two flying wires on different pins as 3.4 3.5 or 5.0 5.1.
Thank's for all who wants to give an advice.
Francesco
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi Francesco,
Since this module does not have UDB components, you have to connect to wires externally.
Alakananda
Alakananda
Alakananda_BG
Hi Francesco,
Alakananda
Alakananda
