Panometric
Level 5
Level 5
10 likes received 100 sign-ins 100 replies posted
What are recommended alternatives to CYBLE-012011-00 since it was discontinued?
MiNe_85951
Level 7
Level 7
Distributor - TED (Japan)
50 likes received 500 replies posted 50 solutions authored
Hi  ,
Since CYBLE-012011-00 is a BLE 4.1 product, it is likely that it has reached EOL, and considering the program volume of BLE itself, types with small memory capacity tend to be difficult to release.
Therefore, the replacement product is CYBLE-212020-01, which supports BLE 4.2.
Flash size : 0 (128kB) to 2 (256KB)
Antenna Type : 1 (PCB Antenna)
EZ-BLE Module type : 2 (PSoC4)
Temp Range : 0 Industrial
Device Identification Number : 11 to 20
Integration Type : 0 (Full Integration With Shield)
Bluetooth Version : 0 (BLE 4.1 ) to 1 (BLE 4.2)
Both packages are the same size(14.92 mm x 19.20 mm).
/* CYBLE-212020-01 Datasheet URL */
https://www.infineon.com/dgdl/Infineon-CYBLE-212020-01-DataSheet-v09_00-EN.pdf?fileId=8ac78c8c7d0d8d...
For reference, all of the BLE modules equipped with Cortex-M0 are listed below, and are compatible up to BLE 4.2 with the end number 01.
MiNe_85951
Level 7
Level 7
Hi  ,
