Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
I have a custom board with CYBLE-012011 module. I am trying to flash the same using kitprog on PSOC 4 BLE pioneer kit. But the kitprog is not able to recognise the target. It says "Unknown Target". I tried updating firmware of kitprog, still no luck. Please help. What could be the show stopper? PFA schematic and images of PCB.
Programming with kitprog requires the Reset pin.
Is the Reset pin connected?
There are two kinds of KitProg.
It is KitProg and KitProg2.
These are different things, which are you using?
I'm using the CY*CKIT-042-BLE Pioneer baseboard to flash my custom PCB.
I am using CY8CKIT-042-BLE pioneer kit to flash my board. I'm using jumper wires to connect the SWD pins to my board.
T N RAJ VIGNESH,
SALIEABS Electronics Engineers LLP.​
No. It is not. But on the same board I soldered CYBLE-212019 module and it got programmed. Anyways I'll give a try by connecting the reset pin also.
Thanks you were correct. One board just flashed without the reset pin connected and the other dint. I connected the reset pin to kitprog, still it dint work. I removed the pull up resistor connected to the reset pin and it then worked.
