CY8CKIt-148 in PSoC Creater: I can not select Launch Tuner on sample project "CE222867-Magsense with Feedback LEDs".
KazKino
5 sign-ins First solution authored First reply posted
I am using  sample project "CE222867-Magsense with Feedback LEDs"  on CY8CKIt-148. I would like to use Launch Tuner. But it is not highlighted so that I can not select it. What is a missimg set-up?
KazKino
Thank you for your quick support. Somehow, I was confused and trying click EZI2C, which is a wrong instance.
Hari
Hi @KazKino
You need to right-click on the MagSense component to launch Tuner.
You may also go to Tools > Component Tuners > MagSense...
Hari
KazKino
