Hello all,
i am developing software for capsense touchpad using CSX method. currently i am able to fetch XY co-ordinate from CSX gesture method.
but i whenever i am trying to get co-ordinates, at that time data is not coming properly. please send any information regarding capsense CSX block .
Thank you for help,
Sanket More
PSoC 4 MCU
Hi @Sanket24 ,
Could you please explain and attach the screenshots of the issue you are facing?
Warm regards
Sobhit
Hello sobhit,
Please find attached program document for CSX method for touchpad. i am trying to fetch coordinated from touchpad. after getting touchpad co-ordinates, i am taking led indication. but indication is not getting. (testing of touchpad) @PandaS
Thanks for your help,
Hi @Sanket24 ,
Could you please share your tuner waveforms for touchpad widget. (Screeenshots)
Warm regards
Sobhit
Hello Sir,
I am not aware about cap sense tuner but i am trying to take attempt on cap sense tuner. please check attached image as I got.
Thanks and regards,
sanket more
Hi Sanket,
You are getting an error because you haven't initialized the EzI2C component in your project.
I would suggest using a code example first. There is a code example on Touch pad for CSX for this device. Try using it, open CapSense Tuner after programing and connect using USB-I2C. Observe the finger tracking in the tuner.
Warm regards
Sobhit
Thanks for reply sobhit,
i am getting an position on the graph of touchpad but it was happens using CSD method. Not an CSX. it is in process. if any comes positive i will revert you back. All things i am trying without using gesture feature.
Thanks and regards,
Sanket more
