I would like to use the CY8CKIT-149PSOC prototyping kit to test my slider design. The idea is to separate the original slider part from the kit. Then I solde 2,54mm pin header connector female on processor part of the kit, and a 2,54mm male connector on my slider board. Then I can connect them, provided that the pinout of my slider board is compatible with the processor part of the kit.
The kit is designed with a snap-away form-factor, so the separation should be possible without damage.
Do you think it is possible?
PSoC 4 MCU
Hi @GeFLo
Yes, this is possible. The only thing to keep in mind is to set the right pin assignments and it will work as usual.
Hari
Hi @GeFLo
Hari
