GeFLo
First like received 10 sign-ins 5 replies posted
The capsense slider of the CY8CKIT-149 is implemented with a Tx  pin , which is required in the  mutual capacitive sensing (CSX) mode. On the PCB design, the TX trace is distributed between every segment.  So hardware is OK for a slider in CSX mode. However when I checked in the "CE220891_CapSense_with_breathing_LED" project with PSCOC Creator, there is no other choice but CSD (self capacitance) for slider.
I don't understand.Is it possible to configure slide in CSX mode? If no, why is the CY8CKIT-149  hardware implemented for It?
Best Regards
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
No, the slider only be supported by CSD. The hardware design aims to be compatible with the future version.
The parameter to select the sensing mode for each widget:
▪ CSD sensing method (Capacitive Sigma Delta) – A Cypress patented method of
performing self-capacitance measurements. All widget types support CSD sensing.
▪ CSX sensing method – A Cypress patented method of performing mutual-capacitance
measurements. Only buttons, matrix buttons, and touchpad widgets support CSX
sensing
LinglingG_46
sensing
GeFLo
Thank you for information. I understand better now.
I have to implement a 9 position slider in my design.  The slider will be necesseraly CSD mode.  Do you recommend to follow the design rules  given in the "AN85951 PsoC4 and PSoC6 MCU CapSense Design Guide" (see the attached fpng) or copy the CY8CKIT-149  slider PCB design?
The CY8CKIT-149  slider PCB design works well but rules given in the design guide seem to guarantee  a perfect solution. I don't know which one is the best.
Best Regards
LinglingG_46
It is recommended that you could follow the AN85951 instead of copy the CY8Ckit-149.
CY8CKIT-149 is a demo kit which should show our customer which function the chip support.
GeFLo
Thank you for your information.  I will follow the AN85951.
One last question, I suppose that the 2k serial resistors, present  in CY8CKIT-149  slider design, must not be implemented in CSD mode.  Can you confirm that?
Best Regards
GeFLo
I saw  in AN85951 (page  144) document that series resistors for Capsense in CSD mode is generally 560 ohms.  I will implement this value.
LinglingG_46
Ok, 560 is the recommended value.
