Hello
The device datasheet of the CY8CKIT-147 PSoC 4100PS Prototyping Kit states that the operating range of the ADC is 0 to 5.5V. I'm trying to configure the ADC as a single ended with 5V reference. I cannot seem to do this. Does this peripheral have this ability? If not, can you refer me to a product line with a dev kit that can handle a 0 to 5V ADC input range?
thanks
Shawn
ispn:40042:1:0
l1:314:1:0
I tried it this morning.
I created a project with following schematic and connected a pot externally.
ADC Configuration
The pot's vdd is connected to the VDD of CY8CKIT-147 and vss is connected to the GND of CY8CKIT-147.
Then I changed the position of the POT from min to max
and read the value from ADC.
Tester Display
5.014 2047
4.975 2047
4.012 1649
3.001 1241
2.074 868
1.032 437
0.506 213
0.000 0
So it seems that we can measure from 0V to 5V, although the configuration of ADC states 3.3V.
Then I modified my main.c as below
#include "project.h"
#include "stdio.h"
#define VDDA 5.0
#define ADC_MAX 0x7FF
char str[128] ; /* print buffer */
void print(char *str)
UART_UartPutString(str) ;
void init_hardware(void)
CyGlobalIntEnable; /* Enable global interrupts. */
UART_Start() ;
ADC_Start() ;
void splash(void)
print("ADC Test CY8CKIT-147 ") ;
sprintf(str, "(%s %s)\n", __DATE__, __TIME__) ;
print(str) ;
int16_t measure(void)
int16_t value ;
ADC_StartConvert() ;
ADC_IsEndConversion(ADC_WAIT_FOR_RESULT) ;
value = ADC_GetResult16(0) ;
return(value) ;
int16_t ivalue = 0 ;
init_hardware() ;
splash() ;
for(;;)
ivalue = measure() ;
sprintf(str, "%d: %d.%03dV\n",
ivalue,
(int)(VDDA * ivalue / ADC_MAX),
(int)(1000 * VDDA * ivalue / ADC_MAX) % 1000
print(str) ;
CyDelay(1000) ;
/* [] END OF FILE */
The UART output to TeraTerm was
moto
Hello Shawn,
Could you please let us know what exactly is the observation at your end ? Is the device malfunctioning ? Or are you getting wrong results ?
Vasanth
Hi Vasanth
I just want to know how to configure the ADC to read input voltages from 0V to 5V.
Shawn
ADC Configuration
Tester Display
5.014 2047
4.975 2047
4.012 1649
3.001 1241
2.074 868
1.032 437
0.506 213
0.000 0
#include "stdio.h"
#define VDDA 5.0
UART_Start() ;
ADC_Start() ;
void splash(void)
print(str) ;
int16_t value ;
return(value) ;
init_hardware() ;
splash() ;
for(;;)
ivalue,
print(str) ;
CyDelay(1000) ;
moto
Thank you. This answered my question.
Shawn Gerber
