FrKi_4757601
is it possible to use the CY8CKIT-142 board as stand alone, only powered by 5 V to receive commands from a self developed App and generate a PWM signal on an output to drive a transitor with a frequency of 200 Hz and depending on the transmitted AT command a duty cycle between 10 and 90 % ?
If so, would it be right to start with the development kit, build the software for the module and for the Android app?
Thanks, all the best,
Frank
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi frki_4757601​,
Yes, you can use CY8CKIT-142 for your application. You can use these training videos for reference - https://www.cypress.com/training/psoc-video-tutorial-series-how-create-android-apps-interact-cypress...
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi frki_4757601​,
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Thanks a lot, als parts still ordered.
