Hi
I am trying to interface a FRDM-STBC-AGM01 sensor board to the above mentioned kit,
Is there I2C available on the CY8CKIT-042-BLE board which can be used for interfacing external I2C devices, if yes then what is i2c bridge? does it pose any conflict?
Can I use UART, (using UART- USB bridge) at the same time while using I2C.
BLE
- cy8ckit-042-ble
- i2c
There is no specific pins compatible for the FRDM-STBC-AGM01 module as such. However for interfacing I2C module with PSoC4-BLE you can use any of the pins assigned by Creator.
You can use the USB-UART bridge in the kitprog same time as the USB-I2C bridge.
If your question is to have the kit acting like a USB I2C bridge then you will need to directly connect the I2C pins to P12.0 (SCL) and P12.1 (SDA) of the PSoC5LP in the kit.
Hima
Hima
