CY8CKIT-041S-MAX
tk1
5 replies posted First like received 25 sign-ins
CY8CKIT-041S-MAX
How to connect a sensor to the header of the main board
NXTY_Tatebayasi
Level 6
Level 6
Distributor - NEXTY (Japan)
100 replies posted 100 likes received 50 likes received
Hi, @tk1
I researched the pins you want to place the sensors on and it appears they are already assigned to the evaluation touchpad, slider, and buttons.
You can open up the pins that are already assigned, but it would be difficult to assign them to the pins (J1, J2, J3, J6, J4) on the main board because of the wiring pattern.
Therefore, as far as I know, the only way to extend the 40-pin connector is to use a board like the link.
https://akizukidenshi.com/catalog/g/gP-10187/
I hope this helps you.
Chihiro Tatebayashi
NXTY_Tatebayasi
Level 6
Level 6
What is the sensor you want to connect to that board?
Chihiro Tatebayashi
tk1
外部タッチボタン一つです
tk1
I want to know how to connect one external electrostatic sensor to the Expansion Headers of the Pioneer Board of CY8CKIT-041S-MAX.
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @tk1 ,
I would suggest you go through the datasheet of the "electrostatic sensor", and connect the sensor to the GPIOs of the S-MAX kit. If the GPIOs need to be configured as special-purpose pins, specific GPIOs need to be configured. You may find detailed information in section 3.1 Alternate pin functions of the datasheet.
Nikhil
NXTY_Tatebayasi
Level 6
Level 6
Hi, @tk1
You can assign a Capsense sensor to any of the GPIOs from the tool.
Capsense can be connected to the pins corresponding to MSC_SENSE described in the datasheet.
The tool uses the capsense configurator. You can either auto assign or manually specify the pins.
For more information, we recommend referring to the ModusToolbox™ CAPSENSE™ Configurator user guide.
And for a touch one button,I guess you can carry out your project by using the capsense configrator to change the capsense pin assignment assigned to the sample code here.
I wish you the best !
PSoC4 msc-capsense-csd-button-tuning.git
PSoC 4100S Max DataSheet
ModusToolbox CAPSENSE Configurator 5.0 User Guide
Chihiro Tatebayashi
tk1
thank you
I want to insert a pin somewhere on J1, J2, J3, J6, J4 on the main board and make one touch sensor.
When I try to configure with Capsense configurator, Device Configurator
Settings cannot be made with the terminals on the main board.
Only pin numbers on the SENSING Expansion Board can be set.
Is it possible to do it with any pin of J1, J2, J3, J6, J4 on the main board?
I want to know how to set it.
NXTY_Tatebayasi
Level 6
Level 6
Hi, @tk1
Chihiro Tatebayashi
tk1
thank you
