HuEd_3452391
25 sign-ins First like received 10 sign-ins
I currently use CY8CKIT-041S-MAX board.  would like use PWM HAL sample.
But I got a set duty error.
I've attached main.c  and log below
****************** HAL: PWM square wave *****************
FAIL: API cyhal_pwm_set_duty_cycle failed with error code
Error Code: 0x04021200
I didn't found the issue on PSOC61.
Please help me with that.
Thank you!
BRs
Sidramesh_S
250 sign-ins 100 replies posted 25 solutions authored
Hi @HuEd_3452391 ,
PSoC 4 HAL is still in the development phase.
I will look into the issue and try it out from my end. Then I can suggest a workaround.
Thanks and regards,
Sidramesh
Hi Sidramesh,
Have you found the root cause? or when your team member could fix this? or you could give me the workaround?
Thank you!
BRs
Edward
Sidramesh_S
Hi @HuEd_3452391 ,
Apologies for the delayed response.
HAL: PWM square wave Code example will not supported for PSoC4 devices.
You can use the below PSoC4- TCPWM-SQUARE WAVE code example instead of it:-
Link :-https://github.com/Infineon/mtb-example-psoc4-tcpwm-square-wave
Thanks and regards,
Sidramesh
