PSoC™ 4 Forum Discussions
HuEd_3452391
25 sign-ins First like received 10 sign-ins
I refered to the I2S TX HAL code example in the HAL document. (https://community.infineon.com/t5/PSoC-4/I2S-sample-project-for-PSoC4S-with-Modus-Toolbox/td-p/36045...)
I catched the waveform by using Logic analyzer below. There are random glitch signal marded in green box.
Please help to fix the random glitch issue.
Thank you!
BRs
Edward
I use the Modus Toolbox version:3.0.0.
HAL version 2.0.0
I use the CY8CKIT-041S-MAX PSoC 4100S MAX PIONEER KIT to test.
Choose the pin as below:
const cyhal_i2s_pins_t i2s_tx_pins = {
.sck = P8_1,
.ws = P8_2,
.data = P8_3,
.mclk = NC
I don't find the issue you report. I attached my test project here.
LinglingG_46
10 questions asked 5 questions asked 250 sign-ins
1: Please disconnect the i2S from other peripherals, then check whether it has the glitch.
2: I use the CY8CKIT-041S-MAX and the test project in attachment, but I don't catch the glitch.
HuEd_3452391
1. I also use the PWM as a Codec's master clock. Unfortunately, Even if I disable the PWM, there was still a glitch issue.
2. I notice that the difference was that you use the PDL API. But as I mentioned before, I used I2S HAL on my end.
Please help to run the I2S HAL which I have attached below. You can press user button to trigger the I2S TX signal.
Thank you!
Best Regards
Edward
HAL version 2.0.0
.sck = P8_1,
.ws = P8_2,
.data = P8_3,
.mclk = NC
