PSoC™ 4 Forum Discussions
paddyliu
5 likes given 50 sign-ins First solution authored
Dears,
请问下:CY8CKIT-037 +CY8CKIT-042 分别运行Sensored BLDC Motor Control、Sensorless BLDC Motor Control、Sensorless FOC Motor Control code examples,若是测试相电流的波形变化, CY8CKIT-037  硬件上是否有电流测试点位,可以直接使用电流表测试波形?谢谢。
RupakC
First like given 50 solutions authored 100 replies posted
Hello @paddyliu
Please probe the resistances R34, R35and R36 on the CY8CKIT-037 motor control kit.
Alternately, you may probe the pin 1 of J2 pin on the same board for Ia. Please measure the voltage of Pin 1 of J2 with respect to ground (Pin 14 of J2).
Let me know if you need any additional help.
RupakC
RupakC
Hello @paddyliu
RupakC
paddyliu
Hi RupakC ,
Got it,thanks.
Paddy
