Augustine_Yeh
Level 4
Level 4
Distributor - Zenitron(GC)
100 sign-ins 5 likes given 50 sign-ins
Hi Cypress
Can you tell us what's difference about RX sensitivity with idle transmitter and RX sensitivity with dirty transmitter  in CY8C4248LQI-BL553  datasheet (page 33) , which one is performance reference for design  , Thank !!
The RX Sensitivity with dirty transmitter test verifies that the receiver sensitivity is within limits for non-ideal signals at normal operating conditions. The non-ideal signals used in this test are within the specification limits but deviate from the ideal case. Please refer to the section "4.5.1 RF-PHY/RCV/BV-01-C" in the attached Bluetooth test suite RF-PHY datasheet for more information. Whereas, the RX Sensitivity with idle transmitter test is performed without any parameter variations like Frequency drift, Frequency deviation etc. of a signal.
P Yugandhar.
Yugandhar
1000 replies posted 5 likes given First comment on blog
The Bluetooth qualification test for sensitivity is done with dirty transmitter on. For range calculations purpose, please consider the dirty transmitter spec.
P Yugandhar.
Augustine_Yeh
Level 4
Level 4
Hi P Yugandhar
Can you express the definition for RX sensitivity with idle idle transmitter and RX sensitivity with idle with dirty transmitter , Thank !!
P Yugandhar.
