CY8C4247AZI-M485  is compatible for any char lcd?
I have vitek lcd display . Is its compatible for psoc 4?
Bob_Marlowe
Level 10
Level 10
Welcome in the forum, subhash!
The Character LCD component is designed for the HD44780 controller which is quite different from the controller within your LCD.
The good news: You may program anything you like into the PSoC, so with some work you can use a display like yours.
Bob
Hi  BOb
how to configure this char lcd?
Bob_Marlowe
Level 10
Level 10
The configurable Items for the character LCD component are restricted to IO-port number and character set. It uses a 4-bit wide bus and 3 control lines, while your Lcd uses 8 bit wide bus and some (I didn't count them) controls.
When using PSoCs you may build your own components to support your own hardware, programming is done in C-language, compiler used is GCC. I would suggest you to
Order a CY8CKIT-043 PSoC4-M  prototyping kit
Download and install latest Creator version for free and start to get acquainted with the way to design with PSoCs watching some of the helpful videos.
Happy coding
Bob
rola_264706
Level 8
Level 8
Subhash: Here is a program to try.  It is for the HD44780 controller. I did some research on the web and they said that your display is compatible with it.
Thanks to all
i have done it
