We will use CY8C4247AZA-M483 PArt Number , There will be a lot of cyber-security codes and FUSA algorithms in the products to be designed, I request you to send a more detailed datasheet with pin-outs in addition to the datasheet accessed from the web page. We will have to examine the product in depth.
Hi @eremirmak ,
You can refer to the datasheet of CY8C4247AZA-M483 for details about the device and further you can refer to the Architecture TRM of 4200M family for details on each Block/System.
I have attached the Architecture TRM document kindly refer.
Thanks and regards,
Sidramesh.
Hi @eremirmak ,
Thanks and regards,
Sidramesh.
