Is it possible to successfully run CY8C4125AXI-483 code on a CY8C4245AXI-483 chip? I don't have the set up yet to test this myself but am being asked by a board vendor due to parts shortage.
PSoC 4 MCU
In the psoc creator project you have for CY8C4125AXI-483 part, right click it on project explorer and go to device selector. Inside that select CY8C4245AXI-483 and rebuild the project. Now you can use the newly generated code for the new device.
Vasanth
Vasanth
Thank you! Still new to PSOC but this seems encouraging. I will get with the others in the group to see if we can work this out.
