PSoC™ 4 Forum Discussions
RaKa_4742981
Hi, I need to program CY8C4124, I have a Jlink Base programmer, here is possible programming but setting to lock chip is not working because Jlink ignore a setting in Hex file. I ordered MiniProg4, and question is if here will work programming using Comand lines, because my programm is running under VB6? Thanks
Rakshith
Hi raka_4742981​,
Yes, you can use PPCLI to program your device with MiniProg4 using command-line interface. You can refer to this thread to get a reference on how to go ahead with that - Re: Miniprog 4 & CLI /ppcli.exe OpenPort Fehler
You can refer to the PSoC Programmer Command-Line Guide for details regarding each of the APIs that you can use.
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi raka_4742981​,
Hope this helps,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Thanks Rakshith,
programmer I will receive this evening and I will check.
But now I have on my desk programmer Jlink Base, which is also able to programm the chip.
But problem is with locking the chip.
I found on page of producer this info: https://wiki.segger.com/PSoC_4xxx_series
Where is written on which location we should write and what, in programming manual from chip I found those locations this is matching,
but I didn't find to write on those locations in programming manual, so I don't know if this info is correct.
But finally when I do this the chip is not locked/protected.
Can you help me also with this?
Rado
Hi
and one more question, is there some possibility to load driver for Miniprog4 for win xp?
Hi RaKa_4742981,
I do not have access to a JLink at the moment. I am checking internally. Please give me some time to get back to you regarding this.
Were you able to program your device using MiniProg4?
Unfortunately no. MiniProg4 requires PSoC Programmer 3.28+ and the minimum requirement for that is Windows 7.
Thanks and Regards,
Rakshith
Thanks and Regards,
Rakshith M B
Rakshith
Hi RaKa_4742981,
I found this thread with a similar issue - Code protection with Segger programmer
Can you please let me know if this helps?
Rakshith
Thanks and Regards,
Rakshith M B
