PSoC™ 4 Forum Discussions
NaMo_1534561
100 replies posted 100 sign-ins 50 replies posted
It can select Direct, SSC, PRS as Sense clock source in Fourth-generation CapSense.
According to the datasheet, when the Sense clock source is set to "Auto", the firmware chooses the setting for each widget.
Specifically, what criteria does it choose?
Also, can the user know which clock CSD is using?
Component version : 5.0
Naoaki Morimoto
BragadeeshV
Hi NaMo_1534561​,
When set as Auto, the component will chose the most optimal sense clock source in the following priority:
1. SSC10
2. SSC9
3. SSC7
4. SSC6
5. PRS12
6.PRS8
7. Direct
1. You can try calculating in this order and try to figure out the best fit.
2. Or, you can use CapSense_GetParam(CapSense_BTN0_SNS_CLK_SOURCE_PARAM_ID, &value) after calling CapSense_Start() to read the sense clock source
Please refer Access and Modify CapSense Register Map in Firmware – KBA2226674  to know how to access the CapSense data structure.
Bragadeesh
Bragadeesh
BragadeeshV
Hi NaMo_1534561​,
1. SSC10
2. SSC9
3. SSC7
4. SSC6
5. PRS12
6.PRS8
7. Direct
Bragadeesh
Bragadeesh
Hello Bragadeesh-san,
Thank you for your answer.
I can confirm which clock source is selected using the API.
Naoaki Morimoto
