Hi everyone,
I'm trying to connect my android phone to a UART_to_BLE_peripheral Project on PRoC BLE device (CYBL10563 - 56LQXI) through Bluetooth connection.
I downloaded the Cypress app (CySmart) on my phone and i can pair it without problems with the PRoC BLE. If i pair the PRoC BLE with my phone through an other app like Serial Bluetooth Terminal (downloaded from Play Store of Google) the app says "Connection failed: no serial profile found -> use long click on device to define a custom profile" or "Connection failed: gatt status 133".
How can do to connect my phone (Android 8.0 OS) with a PRoC BLE through UART_to_BLE_peripheral Project?
I want to do pairing to communicate with a serial bluetooth console app from my android phone to my PRoC BLE device.
Anyone can help me?
I have attached the projects (UART_to_BLE_peripheral and UART_to_BLE_central) which i'm using with PSoC Creator 4.2.
Daniele
BLE
Hi Daniele,
There are many 'Serial Bluetooth Terminals' which supports standard Serial Profile + Some vendor specific serial profiles and does not support all custom serial profiles by default. To create your own custom serial profiles as the error shows, you have select the custom profile option in your app and the supported services and characteristics in your peripheral project will be discovered by the Serial Terminal Program. Then connect the device.
Also, in your peripheral code rearrange the below code snippet --
case CYBLE_EVT_GATTS_WRITE_REQ:
writeReqParam = (CYBLE_GATTS_WRITE_REQ_PARAM_T *) eventParam;
if(CYBLE_SERVER_UART_SERVER_UART_TX_DATA_CLIENT_CHARACTERISTIC_CONFIGURATION_DESC_HANDLE == \
writeReqParam->handleValPair.attrHandle)
errorCode = CyBle_GattsWriteAttributeValue(&(writeReqParam->handleValPair), \
0, &cyBle_connHandle, CYBLE_GATT_DB_PEER_INITIATED);
if (CYBLE_GATT_ERR_NONE == errorCode)
//CyBle_GattsWriteRsp(cyBle_connHandle); //GYAN
#ifdef PRINT_MESSAGE_LOG
UART_UartPutString("\n\rNotifications enabled\n\r");
UART_UartPutString("\n\rStart entering data:\n\r");
#endif
break;
-Gyan
