Hi All,
I have come across a sample program from the Cypress Website that focuses on the BLE Battery Level. However, this program only allows PSoC 6 BLE, whereas I need to use PSoC 4 BLE for it. Here is a link to the website:
http://www.cypress.com/documentation/code-examples/ce215119-ble-battery-level-psoc-6-ble
When I downloaded the program and tried to change the 'Device Selector' from the original device to whatever PSoC programming board I was using (CY8C4247LQI-BL483), I got an error message saying that the new device I have chosen is not compatible with the one that was already there.
Is there any way to fix this, or can I not use PSoC 4 BLE for this program?
Andrew Collins
BLE
Andrew
CE215119 is the demo code for PSoC6 BLE. There is an example code called BLE_Battery_Level for PSoC4 BLE also. Please follow the steps to find the PSoC4 BLE's demo code: Open Creator->File->Code examples-> Device family:PSoC 4200 BLE, filter by: BLE_Battery_Level-> Create project.
As in CE215119, there exists a demo code's user guide, followed the user guide's steps and you can import the demo code into PSoC4 BLE also. The profile and theory should be similar but the firmware should be tinny difference.
Jenson
