01:21 AM
Jul 05, 2018
01:21 AM
I'm now on design/schematic-phase for the CY8C4024LQI-S411 - based on above mentioned program-example (but with 9 buttons).
The Pin-configuration I have chosen as follow:
Now I'm not sure, if I need to connect wco_in and wco_out to capacitors because above mentioned program is using the watchdog??
also I'm not sure about follow capacitor see below, does I need it?:
thank you very much
Labels
02:31 AM
Jul 05, 2018
02:31 AM
CY8C4024LQI-S411(PSoC4S) device can work watchdog without WCO. If you do not want to mount WCO, you can ignore C9/C12 capacitors.
Also, C3 capacitor does not used for CapSense operation or watchdog.
Brandon
