arthurliu
Distributor - Yuban(GC)
25 replies posted 50 sign-ins 10 questions asked
Hi
I am using cy8ckit-042 and cy8ckit-022 for testing, and I would like to ask how the following code implements reading values from eeprom. I did not see any assignment or eeprom operations on this array.
Gautami_12
50 likes received 100 solutions authored 250 replies posted
Hi @arthurliu ,
Please go through the document PSoC® 4 Capacitive Liquid Level Sensing . Every Code example has a related document that displays while you import project on PSoC Creator.
Also please refer to the above screenshot.
Warm Regards,
Gautami J
Gautami_12
Hi @arthurliu ,
Warm Regards,
Gautami J
arthurliu
Hi
I have tried to modify the document before, but after the modifications are completed, the compilation will report 6 errors.
Hi @arthurliu
There is typo in Errata information
sensorEmptyOffset[i]=((volotile int16*))eepromEmptyOffset)[i];
 should be
sensorEmptyOffset[i]=((volatile int16*)eepromEmptyOffset)[i];
