T-elospathic
We noticed that the CAN error return macro returns 1x in binary with a CAN bus-off error, while the macro/define for BUS OFF is set to 0x10 (hex). We believe this is a typo/error in the api itself, as the CPU returns 0x02 and not 0x10. In fact, the register only has 2 bits in address 0x402E000C, 17:16 for ERROR_STATE, and is not able to return 0x10, only "1x" (binary).
This is with PSoC Creator 4.4 and the latest CAN block. In the generated source code it says:
/* Error status of CAN */
#define CAN_ERROR_ACTIVE (0x00u)
#define CAN_ERROR_PASIVE (0x01u)
#define CAN_ERROR_BUS_OFF (0x10u)
When it SHOULD say (but used as a mask):
#define CAN_ERROR_PASSIVE (0x01u)
#define CAN_ERROR_BUS_OFF (0x02u)
The module IS returning 1x (binary) and not 0x10. So, we believe this to be a bug in the API. PSoC 4100S
BragadeeshV
Hi @T-elospathic ,
Thank you for pointing out the bug. We confirm that this is a bug in the component. We have filed an internal request to correct this error. As a workaround you can define a new macro with mask 0x02 for  CAN_ERROR_BUS_OFF and use the CAN_GetErrorState API since this API doesn't have any issue with returning the right bits for bus off condition.
Thank you for your interest in Infineon products.
Bragadeesh
BragadeeshV
Hi @T-elospathic ,
Bragadeesh
