Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
kartheek_adivi
I'm new to the CapSense Kits. I've a PSoC 4100S Pioneer Kit. It has a trackpad on it.
I want to implement matrix buttons or may be multiple buttons. Where can I get those sensors and how to choose them (If there are a lot of options)? I hope it is not like I can use the same trackpad for multiple buttons or matrix button implementation.
Kartheek Adivi
LinglingG_46
10 questions asked 5 questions asked 250 sign-ins
You can remove the trackpad, and use the coil to act as a button.
If you remove the trackpad, then the device has enough pins to connect.
LinglingG_46
What do you want to do? We need to know your demand then give you some suggestions.
I can't get what your want from this sentence, maybe you could explain it in details.
kartheek_adivi
@LinglingG_46, There is a trackpad on PSoC 4100S. I want to implement an application which uses 8 buttons. How can I achieve that with this board? Do I need to buy some sensors and remove the trackpad?
LinglingG_46
Marshal_Zhang
Level 4
Level 4
25 sign-ins 10 replies posted 10 sign-ins
According to Capsense's design requirements, redesign a PCBA. This should be simpler.
