Hi people,
I get this error when executing my project, which is based on a BLE connection where I use the devices shown in the attached photo.
I tried to uninstall and reinstall PSoC Creator but it still gives me the same bug.
Any ideas to fix it? It is the only mistake it gives me.
Greetings
I tried to build your project.
The last 4 lines were.
.\CortexM0\ARM_GCC_541\Debug\main.o:(.bss+0x0): multiple definition of `deviceConnected'
.\CortexM0\ARM_GCC_541\Debug\BLE_APP.o:(.bss+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
--------------- Build Failed: 10/27/2019 20:49:24 ---------------
This error message suggests that both you and the library have identifier named "deviceConnected"
In your main.c there were two lines which has "deviceConnected".
So I changed "deviceConnected" to "device_connected" in your main.c.
And now your project is build-able.
Attached is modified project of yours 😉
moto
