PSoC™ 4
user_3636091
New Contributor
I used PSoc Creator4.2 to create a project with Capsense_ADC module, and a compiler error occurred. The code of the error is as follows. How to solve this problem? Thank you!
MotooTanaka
Esteemed Contributor
I've just downloaded your project and tried
(1) Menu Build > Clean Design01
(2) Menu Build > Build Design01
And I could compile your project without problem
So, I think the problem is not the design but the IDE/Environment.
I would suggest
(1) Clean the design and re-build
(2) Menu Help > Update Manager
    Update outdated parts if any then try (1) again
(3) In case above does not work, try uninstall and re-install PSoC Creator
moto
