shge_4395051
Level 4
Level 4
25 sign-ins 25 replies posted First solution authored
Hello
When I add an I2C  SCB block to my design, I receive a build error.  My resources Window does not indicate that I am maxed out on any available components.
I have a feeling it is conflicting with my Soft Uart component.  However, if I remove the soft UART, it still will not build.  My design worked until I added the I2C block.
Any help would be appreciated.
thanks
--------------- Build Started: 01/16/2020 14:50:49 Project: PSOC_SPM, Configuration: ARM GCC 5.4-2016-q2-update Debug ---------------
cydsfit.exe -.appdatapath "C:\Users\shawng.WAGNER\AppData\Local\Cypress Semiconductor\PSoC Creator\4.2" -.fdsnotice -.fdswarpdepfile=warp_dependencies.txt -.fdselabdepfile=elab_dependencies.txt -.fdsbldfile=generated_files.txt -.fdsreffile=referenced_files.txt -p "C:\Users\shawng.WAGNER\Documents\PSoC Creator\PSOC SPM\PSOC_SPM.cydsn\PSOC_SPM.cyprj" -d CY8C4247AXI-M485 -s "C:\Users\shawng.WAGNER\Documents\PSoC Creator\PSOC SPM\PSOC_SPM.cydsn\Generated_Source\PSoC4" -- -yv2 -q10 -ygs -o0 -v3 -.fftcfgtype=LE
Elaborating Design...
HDL Generation...
Synthesis...
Tech Mapping...
ADD: pft.M0040: information: The following 2 pin(s) will be assigned a location by the fitter: \I2C_Module:scl(0)\, \I2C_Module:sda(0)\
Analog Placement...
Analog Routing...
Analog Code Generation...
Digital Placement...
Digital Routing...
Error: rtr.M0004: E1216: Routing of net __ZERO__ Failed. Source : :udb@[UDB=(1,0)]:pld0:mc1.q, Sink : :m0s8scbcell_0.uart_rx
Error: rtr.M0004: Error routing design: Routing Failed (12)
Dependency Generation...
Cleanup...
Error: fit.M0050: The fitter aborted due to errors, please address all errors and rebuild. (App=cydsfit)
--------------- Build Failed: 01/16/2020 14:50:55 ---------------
Ekta
First like given 250 solutions authored 100 likes received
Hello Shawn,
Go to the Build settings> Code Generation > Set Synthesis Optimization Effort to Exhaustive and Build the project again.
Please let me know if this resolves the issue.
Best Regards
Ekta
Ekta
Hello Shawn,
Best Regards
Ekta
This worked. Thank you!
Shawn Gerber
Manufacturing Engineer Manager
Wagner Electronic Products Inc.
326 Pine Grove Road
Rogue River, OR 97537
Office: (541) 582-0541 x238
http://www.WagnerMeters.com/<http://www.wagnermeters.com/>
