almc_4008691
First like received
I have a problem when I want to save data from bridge control panel because I dont have all the data as shown in the chart part.
It never begin at 0 count when I exctract the data and I can see it in the table too.
But my chart begin at 0 count so it's a bit strange.
Can you help me?
Thank you in advance,
Alex
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
If you want to "read" the values, how about doing something like below?
#include <stdio.h>
void SendTxData(void)
  char str[32] ;
  TX_PutCRLF() ;
  sprintf(str, "%04X %04X %04\r\n",
    CapSense_rawFilterDatal[PROXIMITY_SENSOR_INDEX],    /* I could not figure out if it was Data1 or Datal */
    CapSense_sensorBaseline[PROXIMITY_SENSOR_INDEX],
    CapSense_sensorSignal[PROXIMITY_SENSOR_IDEX]) ;
  TX_PutString(str) ;
moto
almc_4008691
First like received
I guess I understood why!
I only have maximum 10000 lines in the excel so I guess it's a maximum?
Any other possibilities to save all the data?
Thank you
Alex
So the bridge control panel is meant for testing in real time or playing around.  It is not meant as a serious data logger.
My suggestion would be, if you want to keep that much data for further analysis, use a UART and a tool like putty to log your output to a file.
almc_4008691
First like received
Thank you ScottA_91!
I have tried on putty but it's unreadable and I dont find the solution.
I get that:
I'm sending my data by bluetooth and I'm using the base project:
I guess it's a problem from the type of data but I dont find how to fix it!
I'm using the same rate 9600 on putty.
Alex
Wait you're taking the raw value and sending it as characters?  Well if you capture that to a text file, and look at it with a hex editor, you'll see your data values.  (Putty is looking at it as if it is ascii, but you've sent raw bytes).
Alternatively, you can use printf and PutString().
MotooTanaka
Level 9
Level 9
#include <stdio.h>
  char str[32] ;
  TX_PutCRLF() ;
  TX_PutString(str) ;
moto
almc_4008691
First like received
Thanks all for you reply.
I have finally wrote a small python program to save data in a csv file.
Thank you
Alex
