YashBhatnagar
First like received 5 sign-ins First question asked
Hi, I want to create a basic project for CY8CKIT-041S-MAX PSOC 4100S MAX PIONEER BOARD of changing the LED intensity using PWM to give it a breathing effect. I want to use the PDL library for this instead of HAL library. Can someone share a basic project that does this. I am very new to this board and ModusToolbox.
Ekta
750 replies posted First like given 250 solutions authored
Hi @YashBhatnagar
We currently do not have a breathing LED project for PSoC 4100S Max device. But there is one that exists for PSoC 6. You can find it here: https://github.com/Infineon/mtb-example-smartio-ramping-led/tree/master
The example uses PDL for PSoC 6.
At your end, you would need to replace these PDL functions in the main with the ones available for PSoC 4.
PSoC 4 PDL API reference guide can be used for going through the PDL functions: https://infineon.github.io/mtb-pdl-cat2/pdl_api_reference_manual/html/index.html
You can go through the design and implementation section of the readme to understand how PWM along with Smart IO's are utilized to get a breathing LED.
Since you need to use PDL, you would also need to configure these resources in your design configurator.
I hope these pointers will help you to create your breathing LED project.
Best Regards
Ekta
NXTY_Tatebayasi
Distributor - NEXTY (Japan)
50 questions asked 25 likes received 250 sign-ins
Hi, @YashBhatnagar -san,
I recommend "TCPWM_square_wave" project.
You can find it within the BSP or GitHub.
https://github.com/Infineon/mtb-example-psoc4-tcpwm-square-wave/tree/master
Actually, I try to porting TCPWM Project  form PSoC Creator to Modus tool box now.
I also seeking useful sample codes to learn how to implement TCPWM on the Modus tool box.
I hope this helps you.
Chihiro Tatebayashi / NEEXTY
Ekta
Hi @YashBhatnagar
Best Regards
Ekta
