I have a bootloader where I set the bootloader version parameter to 0xabcd. I enter the bootloader using the bootloader command and then I check the meta data using the get metadata command, I get the right bootloader version 0xabcd. I then flash the chip with a new bootloadable using the bootloader and I reset the chip. After the chip resets, it enter the bootloader and doesn't exit until I send it a command. However when I send it enter bootloader using the bootloader command and then I check the meta data using the get metadata command, I get the wrong bootloader version. Is this expected behavior or am I missing something?
PSoC 4 MCU
What I am asking is, is this expected behavior? Or am I missing something?
>>Yes this is the expected behaviour.
Can you please refer the below attached thread and let us know if that helps you.
Alakananda
I've already looked at Bootloader_GetMetadata and tracked down the address of the bootloader version, however I read it before I flash the chip with a bootloadable and then after I flash the chip and the value in that address changes. What I am asking is, is this expected behavior? Or am I missing something?
