Good afternoon (o;
According to the "Bootloader and bootloadable datasheet" the application checksum is defined as:
"The basic summation checksum is computed by adding all the bytes (excluding the checksum) and then taking the 2’s complement ."
So for the SCB_Uart example it writes in the checksum field the byte 0x60...
But when I walk through the hex file and sum up all bytes I get "0x8F"...
Does "excluding the checksum" mean it includes the other meta fields at address 0x7FC0 as well like application length and so on?
PSoC 4 Architecture
Bootloader datasheet says
Bootloadable Application Checksum:
This is the basic summation checksum that is computed by adding all the bytes of the bootloadable application image (excluding the metadata section)
Bob
