I'm designing an app that connects to a sole Bonded device and while connected will broadcast a non-connectable, whitelist-only advertisement to up to 8 different devices.
Is the Bonded device stored in the same maximum-8 array, so that I would have to remove the bonded device address before populating the whitelist address?
If so, after removing the bonded address, populating the whitelist, advertising, and clearing the whitelist, how would I add the bonded device back to the bonded list for future connecting would StoreBondedDevices still apply and would/could I call it during connection or after disconnect?
I'm using component 3.10 and noticed in the docs that CyBle_GapRemoveDeviceFromWhiteList removes all devices, bonded and whitelist, but a parameter to allow them to be removed separately isn't available with this version. Is it a future release, or is it dependent on chip?
Thank you.
BLE
As of now, removing the devices separately from whitelist and bonding is not available.
-Madhu Sudhan
-Madhu Sudhan
