BhSa_4078721
10 replies posted 10 questions asked 5 replies posted
Hi....
Is there any part from cypress having bluetooth which can operates as both, bluetooth HID keyboard as well as bluetooth touchpad??
VenkataD_41
You can go through the following code example with Reference Design kit where there is a CapSense Touchpad to detect the mouse position. Based on the Touch locations the pointer position is calculated. After referring the below code example, please check "BLE HID Mouse" code example as reference for your BLE Touch pad application from the PSoC Creator.
https://www.cypress.com/documentation/development-kitsboards/cy5672-proctm-ble-remote-control-refere...
Please note that the above project is designed with PRoC BLE device. For your present application you need to design with PSoC 4 BLE device. The firmware would be almost same.
Ganesh
VenkataD_41
There are different families of devices from Cypress which can solve your requirements. For example PSoC 4 BLE and PSOC 6 BLE families. For more information, please refer the following datasheets.
https://www.cypress.com/file/416486/download
https://www.cypress.com/documentation/datasheets/psoc-6-mcu-psoc-63-ble-datasheet-programmable-syste...
Also, please refer the following web page for more information on our BLE and Bluetooth products:
https://www.cypress.com/products/bluetooth-le-bluetooth
Thanks and regards
Ganesh
Thanks for the references....
This can definitely solve my requirement.
Can I get any sample software to configure BLE block..
I have already configured the BLE HID keyboard but do not have idea about how to configure same BLE block for touchpad..
Many thanks.
Currently there was no example project on BLE touch pad application. Please check "BLE HID Mouse" code example as reference for your BLE Touch pad application from the PSoC Creator.
P Yugandhar.
VenkataD_41
Ganesh
