haki_2218686
Hi
My project is based on the links below.
  (Link : PSoC-4-BLE/100_Projects_in_100_Days/Day010_Observer at master · cypresssemiconductorco/PSoC-4-BLE · ...
The main purpose is to scan surrounding beacons.
However, I would like to reduce the rx power of the observer, because the beacon, which is far from the observer, is also scanned.
I know that the LNA_GAIN value in the BLE_BLERD_CFG1 register adjusts the rx power.
I can see the VHG, HG, IGH, MH, LG, and VLG settings in the BLE_Register_TRM document.
(reference link : PSoC 4100-BL/4200-BL Family: PSoC® 4 BLE Registers Technical Reference Manual (TRM) )
I have one questions here.
Do you actually know how many dBs the above settings are?
I want to know the db value of rx that I get through the above settings.
Thansk
Positive dB is a stronger signal; Negative dB is the same proportional change in signal strength, but it is decreased signal strength instead.
The Normal vs High Gain modes differ by the 2dB difference, which is a roughly 1.6~ times increase in signal reception sensitivity.
The radio lists -89 dB as the default RX sensitivity as that is the fractional power of a signal from a unity-gain transmitter that can be correctly received. For example, a radio transmitting at 1 W/m^3 would be receivable by the receiver at a -89 dB drop in signal strength before reaching the receiver, this dB value corresponds to 0.0000000126 W/m^3 of signal strength needed to function. (This is a rough calculation, but it demonstrates the math and concept pretty well.)
No idea how the LNA Gain matches to the CyBle_SetRxGainMode() function, but it could be a difference between the TRM and the cypress function that sets the settings found in the TRM to specific configurations for each setting/mode.
Atm the TRM isn't letting me download it from the Cypress site, but I'll try again later. At a guess, it would be somewhere on the order of 1.5 dB, 3 dB, or 6 dB (3 dB is double).
Looking in the TRM, page 347 refers to the LNA gain setting of 101 being 66 dB, and the potential to boost the sensitivity by 2-3 dB at the expense of increased current at that setting level (sounds like it will boost it at other levels with little-to-no effect.)
With the highest being 66 dB, and the lowest being 0 dB, I would see the steps as 13.2 dB
I saw the component document at the link below.
(http://www.cypress.com/documentation/component-datasheets/psoc-creator-component-datasheet-bluetooth...
In p84, I saw the function "CyBle_SetRxGainMode"
In the function description, the "CYBLE_BLESS_HIGH_GAIN_MODE" setting is called -91dB.
What is the difference between minus db and plus db?
And how does the LNA Gain and CyBle_SetRxGainMode settings match?
