I got a SSD1306 OLED display from eBay to work using some code contributed by a community member. The code is based on an Adafruit library. See the attached project. I cannot, however seem to get a bitmap to display. I am using this program to convert a .bmp to a char array, but it comes up on the display as garbage, though it seems there is some hint of the image there.
Library:
https://github.com/adafruit/Adafruit-GFX-Library
Converter tool:
http://en.radzio.dxp.pl/bitmap_converter/
Any ideas?
Thank you,
Tom
Never mind, the code works fine, I just had to use horizontal byte orientation instead of vertical in the converting software. These OLEDs are beautiful and cheap on eBay. No excuse not to have one on a project.
Thank you,
Tom
One other question. Is there a simple way to store initial data in flash besides using the EM_EEPROM? Arduino has a PROGMEM designator, is there something similar in PSOC?
I am trying to store bitmap data for an OLED display, and it does not work in just a standard array. Why can't the processor recall this array after power off? It seems to recall other arrays and variables that I set up as constants.
Thank you,
Tom
You may declare an array as
static const uint8 MyArray[YourSize] = {0x01,0x02,... and so on.
"const" and the initialization are absolutely requred to have that "variable" located in flash.
Structs are allocated in flash similarly.
Bob
Your program is straightforward and I cannot see an uninitialized variable. So a chance might be that there is a timing issue when toggling power. Does a reset show the same problem?
Bob
A reset preserves the data (and animation) and a power off does not.
Thank you,
Tom
then I would suggest to put a delay (0.1 to 0.5s) before initializing the display.
Bob
Right on! 100ms seems to be a good minimum for what I have.
Thank you,
Tom
You are always welcome, Tom!
Bob
Not to rain on your parade, but would it not be prudent to figure
out approximately where the delays are coming from and their cause,
size ? Just to be sure one device to another you have predictable behaviour
and can be assured that the delays you currently are implementing are not
masking a more serious problem that may bite you in the great divide at
a later time.
Just a thought.
Regards, Dana.
Sorry to once again appear quite ignorant, but how would I go about this? It is a fairly simple piece of code right now, how would I tackle it?
Thank you,
Tom
I did not go deep into the specs of your OLED display, but as most devices there is a time needed before it is able to react to commands after power is supplied.When the PSoC is ready first and starts sending commands that would go amiss.
A review of the datasheet concerning power on sequence shows a delay of 100ms after initialization.
Additionally I would monitor the power supply when switching on, there could be some unwanted glitching or a ramp too slow.
Bob
These are the requirements for power up and down -
Tom,
On the link you listed from Adafruit i do not see any down loads for PSoC adjusted code. Were did you get the adjusted code for PSoC version for SSD1306?
Scott
