PSoC™ 4
I want to measure the data throughput using BLE 4.2 as done in the 100_Projects_in_100_Days/Day024_Throughput.
But for some reason this code is not working on BLE 4.2, it "hangs" after a connection has been established.
Anybody knows a fix for this problem ?
Jakob
This thread may be of some use: BLE 4.2 max payload throughput
Similar question to yours I believe. If you run the program with a debugger, you should be able to do some watching of the variables to see what is getting stuck/freezing.
