TeCh_3034126
I am using CYBLE-214009-EVAL for my development.
In my development, I am using a Android phone (with CySmart APP) to test the device.
It is ok along the development.
In user-trial run, the device cannot connect with iPhone X correctly after several days.
CYBLE_EVT_GAP_AUTH_FAILED, reason: AUTHENTICATION_TIMEOUT” happens.
HOWEVER, the problem device can connect with other Android phones and even iPhone SE/iPhone 6.
Can anyone help me on the issue?
Is there any way to capture more debug information?
Terry
Yugandhar
1000 replies posted 5 likes given First comment on blog
Hello Terry,
You may have to check if your PSoC4 BLE component follows the Advertising and Connection parameters guidelines from Apple to have a stable connection with an Apple product. Here's the link:
https://developer.apple.com/library/archive/qa/qa1931/_index.html
P Yugandhar.
Yugandhar
Hello Terry,
P Yugandhar.
Will check it. Thanks!
