APe_3909046
5 replies posted First reply posted First question asked
Im using a BLE222014-01 for a project and I would like to know if this chip is capable of doing continuous scanning with intervals of 1 sec while sending  the scan result to another device. I've been looking through the 101 projects but I've only found projects sending data through UART.
Once that is completed I would like to make a small mesh consisting of three devices. Device 1 scans and sends data to device 2 while it scans and sends results of scan1 and scan2 to device 3 which does a final scan and sends all data to a pc/mobile but im not sure if this chip is capable of maintaining two simultaneous connections while scanning.
Thanks in advance,
Alvaro
For PSoC4BLE Device,  you can refer to the Day049_BLE_Mesh_Flood and Day052_BLE_Mesh_Directed projects from the GitHub for more information on the BLE Mesh Network.
For  CYBT-353027-02  device, you can select 353027 in modus tool box and will be able to see many mesh applications which might be helpful.
P Yugandhar.
Yugandhar
1000 replies posted 5 likes given First comment on blog
1. If you set both scan window and scan interval as same values then the device will scan continuously. Please refer to the section "GAP Settings Tab – Scan Settings" in the BLE component datasheet for more information.
2. PSoC4/PRoC BLE devices can make only one connection at a time. For your application,  you can refer to the Day011_Central_Observer, Day010_Observer and Day009_Dynamic_Broadcaster from GitHub.
P Yugandhar.
APe_3909046
I bought some CYBT-353027-02  to try their mesh capabilities. With this deviceI would be, in theory, able to read both of the "BLE222014-01 scanners" simultaneosly right?
Thanks for your response,
Alvaro.
P Yugandhar.
