PSoC™ 4 Forum Discussions
Hi community,
I'm currently implementing a BLE OTA upgrade feature with an upgradable stack based on the examples provided in PSoC Creator on my custom designed board.
In these examples it is possible to switch between the applications by pressing button SW2 during startup of the chip. At my custom designed board I got no input buttons to perform this operation.
What would be the best solution to switch between the applications without buttons?
Best
Philipp
himam_31
You can send a specific command over BLE to switch between. Please let us know if this is feasible in your design.
Hima
himam_31
Hima
This would be feasible.
- How can I switch between the two applications in CySmart PC app?
- How must the code be changed to achieve this?
himam_31
Hello
You will need to send command over BLE and in the application you will need to make the other application as active and then perform a software reset.
Much change wont be there in code.
Hima
Thanks, I use a characteristic, which will set the bootloader as active application and performs a reset, when it is written.
