AkRo_4053566
I am trying to implement the "Find me Target" program on PSoC 6 protoboard but Having trouble with the LED to light up as it should .
It works with PSoC6 pioneer board without any problem.
My pin connections are all correct and used the code (CE217637) as attached.
NazarP_56
25 solutions authored 10 sign-ins 50 replies posted
Hi akro_4053566,
Please use latest version (1.10) of CE217637_BLE_Find_Me example. You can get it in PSoC Creator: File->Code Examples.
Also do not forger to do pins reassignment according to Table2 of datasheet:
Nazar
NazarP_56
Hi akro_4053566,
Nazar
AkRo_4053566
Thank you for your reply NazarP_56​. I did use the latest version of the code and I am sure my pin assignments are all correct. But I am still having the same problem!.
Hi AkRo_4053566,
I asked about CE version because you attached v1.0 (not v.1.10). Could you attach CE (after all modifications, pin reassignment, ect)? So I can check it on my module.
Also, per the description, you have a problem with LED. Could you confirm, that the device is advertising, and you able to connect to the device from phone or PC Dongle?
Nazar
