After building and compiling the program, the green led started blinking when I pushed switch 2 and the motor didin´t run.
I already measured all the voltages in the board and it seems that they are ok.
Could somebody help me!!
Túlio
Hi Marco,
Can you please try the sensorless BLDC motor control project. And make sure the jumpers are correct as per the user guide:
http://www.cypress.com/file/141156/download
Please confirm you had followed the step mentioned :
5.3 Sensored BLDC Motor Control Code Example
Jobin GT
- I am using psoc creator 4.2
- code: sensored bldc
* Project Name : Sensored BLDC Motor Control
* File Name : motor.c
* Version : 1.0
* Device Used : CY8C4245AXI-483
* Software Used : PSoC Creator 4.2
* Compiler Used : ARM GCC 5.4.1
* Related Hardware : CY8CKIT-042 PSoC 4 Pioneer Kit + CY8CKIT-037 PSoC 4
* Motor Control Evaluation Kit
* Copyright (2018), Cypress Semiconductor Corporation. All rights reserved.
* This software, including source code, documentation and related materials
* (“Software”), is owned by Cypress Semiconductor Corporation or one of its
* subsidiaries (“Cypress”) and is protected by and subject to worldwide patent
* protection (United States and foreign), United States copyright laws and
* international treaty provisions. Therefore, you may use this Software only
* as provided in the license agreement accompanying the software package from
* which you obtained this Software (“EULA”).
* If no EULA applies, Cypress hereby grants you a personal, nonexclusive,
* non-transferable license to copy, modify, and compile the Software source
* code solely for use in connection with Cypress’s integrated circuit products.
* Any reproduction, modification, translation, compilation, or representation
* of this Software except as specified above is prohibited without the express
* written permission of Cypress.
* Disclaimer: THIS SOFTWARE IS PROVIDED AS-IS, WITH NO WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, NONINFRINGEMENT, IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. Cypress
* reserves the right to make changes to the Software without notice. Cypress
* does not assume any liability arising out of the application or use of the
* Software or any product or circuit described in the Software. Cypress does
* not authorize its products for use in any products where a malfunction or
* failure of the Cypress product may reasonably be expected to result in
* significant property damage, injury or death (“High Risk Product”). By
* including Cypress’s product in a High Risk Product, the manufacturer of such
* system or application assumes all risk of such use and in doing so agrees to
* indemnify Cypress against all liability.
#include <project.h>
#include "motor.h"
#include "userinterface.h"
#include "getvalue.h"
/* UI_MOTOR_STATUS Status */
UI_CMD UI_Cmd;
UI_DATA UI_Data;
uint16 speedRef = 0; /* Motor speed Reference */
uint16 speedCur = 3000; /* Current motor speed. */
uint16 preSpeedCur = 0;
uint16 preCntCaptur = 30000;
uint8 dutyCycle = 0; /* really now used as BYTE since use 8-bit PWM */
uint16 pwmCnt = 0;
uint8 firstRun = 1;
uint8 ocBlankCnt = 0;
Error_T errorState = no_error;
uint8 stateSys = STATUS_STOP;
* Function Name: pwm_isr
* Summary:
* This function is PWM ISR. When TC happens, it increases PWM ticker, clears flag and
* enables over current protection ISR after startup.
* Parameters: None
* Return: None
CY_ISR(pwm_isr)
pwmCnt++;
/* Avoid the current pulse interference in motor start-up*/
if (UI_Cmd.run)
if(firstRun == 1)
ocBlankCnt++;
if (ocBlankCnt > 2) /*Ignore the first 2 PWM period = 50uS*3=150uS, then enable over current ISR */
firstRun = 0;
ocBlankCnt = 0;
isr_oc_Enable();
isr_oc_ClearPending();
/* Calculate the real time motor speed every 2000 PWM period*/
if(pwmCnt >= 2001)
pwmCnt = 0;
PWM_Drive_ClearInterrupt(PWM_Drive_INTR_MASK_TC);
* Function Name: speed_measure_isr
* Summary:
* This function is ISR for motor speed measurement.
* Parameters: None
* Return: None
CY_ISR(speed_measure_isr)
uint16 cntCaptur = 0;
cntCaptur = Counter_Spd_ReadCapture();
speedCur = preCntCaptur - cntCaptur;
/* If speed is too low, Regard motor is stopped*/
if(speedCur > 5000) /* < 300Rpm*/
speedCur = 5000;
/* filter for speed measured */
speedCur = (preSpeedCur >> 2) + (preSpeedCur >> 1) + (speedCur >> 2);
preCntCaptur = cntCaptur;
preSpeedCur = speedCur;
Counter_Spd_ClearInterrupt(Counter_Spd_INTR_MASK_CC_MATCH);
* Function Name: over_current_isr
* Summary:
* This function is ISR for over current protection. It updates the error state flag.
* Parameters: None
* Return: None
CY_ISR(over_current_isr)
UpdateStatusError(); /* If over current happens, stop motor*/
errorState = overCur;
LPComp_OC_ClearInterrupt(LPComp_OC_INTR_RISING);
* Function Name: Init_UI_FW
* Summary: This function initializes parameters used in motor running.
* Parameters: None
* Return: None
void Init_UI_FW(void)
/* Setting UI Initial parameter*/
UI_Data.Dir = CLOCK_WISE;
UI_Data.maxSpeedRpm = 4000;
UI_Data.minSpeedRpm = 500;
UI_Data.speedRpmRef = 1000;
UI_Data.polePairs = 4;
UI_Data.maxCurr = MAX_CURR_MEDIUM;
UI_Data.kp = 500;
UI_Data.ki = 50;
* Function Name: Init_HW
* Summary: This function initializes system hardware peripherals
* Parameters: None
* Return: None
void Init_HW(void)
/*PWM Initialization*/
PWM_Drive_Start();
/*Enable PWM, disable PWM IO output*/
CtrlReg_PWMOut_Write(0x01);
/*Speed Counter Initialization*/
Counter_Spd_Start();
/*For voltage sample*/
ADC_SAR_Seq_1_Start();
/*For over current protection*/
IDAC_Iref_Start();
IDAC_Iref_SetValue(0x7d);
LPComp_OC_Start();
/*UART Init*/
UART_BCP_Start();
isr_pwm_Start();
isr_pwm_StartEx(pwm_isr);
isr_pwm_Enable();
isr_spd_Start();
isr_spd_StartEx(speed_measure_isr);
isr_spd_Enable();
isr_oc_Start();
isr_oc_StartEx(over_current_isr);
isr_oc_Disable();
* Function Name: Init_UI_HW
* Summary: This function initializes hardware peripherals for user interface
* Parameters: None
* Return: None
void Init_UI_HW()
UpdateStatusInit();
/* [] END OF FILE */
Hi Marco,
Jobin GT
The jumper in psoc 42 was connected in 3V instead of 5V. Now the motor is running.
Thanks!!!
