PSoC™ 4 Forum Discussions
Lin_Qiang
Level 4
Level 4
5 likes given First like given 50 replies posted
When I use the SFlash update tool to clear the SFLash data, I find that the data in the normal Flash area is all cleared. Is this normal when using the SFlash update tool?
LinglingG_46
10 questions asked 5 questions asked 250 sign-ins
No, the flash should not be cleared.
LinglingG_46
Helllo LinglingG_46,
What is causing the tool to clear normal Flash? Although I have modified the tool configuration linked below, but only modifying the adaptation to Miniprog4, it should not lead to the clearing of normal Flash.
If you know the reason, please give pointers, thank you very much.
https://community.infineon.com/t5/PSoC-4/PSoC-4-Clear-SFlash-Program/m-p/265875
Best Regards
Lin_Qiang
Level 4
Level 4
I modified a few things and the problem has been solved.
Could you share your debug experience here, and update the working tool?
