I am entirely new to programming in any language and have purchased a CY8CKIT-042 Pioneer Kit. I have went through PSoC 101 lessons 1-9.
I have some questions from each lesson that may seem trivial but please humour me.
Lesson 1- Question 1
Parallel programming, after the lesson was finished Alan said you should try something new, for me I flashed different LED's, red then green, then blue. I had the idea to make this sequence.
Each LED would be flashing on off at a different rate, using the firmware, to do this I would need parallel programming where it would, execute all programs at the same time. I am pretty sure this is possible but cannot find anywhere that shows how it is done. Could you please assist?
ispn:39611:1:0
l1:314:1:0
Although you were talking about parallel programming,
my previous samples were quite single-task style.
So today I tried to imitate some parallel programming flavors.
At first I separated doLEDs() function into individual LED handler
do_red(), do_green(), do_blue().
Then I changed the timer to 1ms timer to imitate "tick."
And for each "tick", I let each handlers take care of their business.
for(;;) {
if (pit_flag) {
do_red(count) ;
do_green(count) ;
do_blue(count) ;
count = (count + 1) % TIMER_PERIOD ;
pit_flag = 0 ;
=== led_test_191114A ===
main.c
#include "project.h"
#define LED_ON (0u)
#define LED_OFF (1u)
#define TIMER_PERIOD 1000
#define RED_PERIOD 1000
#define GREEN_PERIOD 500
#define BLUE_PERIOD 250
volatile int pit_flag = 0 ;
CY_ISR(timer_isr)
Timer_1ms_ClearInterrupt(Timer_1ms_INTR_MASK_TC) ;
pit_flag = 1 ;
void do_red(int count)
if ((count % RED_PERIOD) < (RED_PERIOD/2)) {
LED_R_Write(LED_OFF) ;
} else {
LED_R_Write(LED_ON) ;
void do_green(int count)
if ((count % GREEN_PERIOD) < (GREEN_PERIOD/2)) {
LED_G_Write(LED_OFF) ;
} else {
LED_G_Write(LED_ON) ;
void do_blue(int count)
if ((count % BLUE_PERIOD) < (BLUE_PERIOD/2)) {
LED_B_Write(LED_OFF) ;
} else {
LED_B_Write(LED_ON) ;
int count = 0 ;
isr_1ms_StartEx(timer_isr) ; /* set isr to the interrupt */
Timer_1ms_Start() ;
CyGlobalIntEnable; /* Enable global interrupts. */
for(;;) {
if (pit_flag) {
do_red(count) ;
do_green(count) ;
do_blue(count) ;
pit_flag = 0 ;
=== led_test_191114B ===
But with this approach all handlers were called at once,
so I changed the main() to slice the timing,
so that each task will be called at different tick timing.
Now task(handlers) are called round-robin style.
main loop of led_test_19114B
for(;;) {
if (pit_flag) {
switch(task) {
case 0:
do_red(count) ;
task = 1 ;
break ;
case 1:
do_green(count) ;
task = 2 ;
break ;
case 2:
do_blue(count) ;
task = 0 ;
break ;
default:
task = 0 ;
break ;
pit_flag = 0 ;
=== led_test_191114C ===
Since I came this far,
I introduced a type "task_type" so that main() can call each member of task_type array.
With this, conceptually any numbers of tasks could be handled,
so this can be a very primitive multi task.
typedef void (*task_type)(int count) ;
main() of led_test_191114C
int count = 0 ;
int task_no = 0 ;
task_type task[] = { do_red, do_green, do_blue } ;
int num_task = sizeof(task) / sizeof(task_type) ;
Timer_1ms_Start() ;
for(;;) {
if (pit_flag) {
task[task_no](count) ;
task_no = (task_no + 1) % num_task ;
pit_flag = 0 ;
main.c (led_test_191114C)
#define LED_ON (0u)
CY_ISR(timer_isr)
pit_flag = 1 ;
} else {
} else {
} else {
int count = 0 ;
int task_no = 0 ;
Timer_1ms_Start() ;
for(;;) {
if (pit_flag) {
pit_flag = 0 ;
If you want to go further, you may want to refer and study Bob-san's master piece,
moto
