About the KILL signal specification of PSoC41xxS PWM
NaMo_1534561
Distributor - Macnica (Japan)
100 replies posted 100 sign-ins 50 replies posted
Can the PWM Kill signal set both of the Line/LIne_n output to "0" (Low) at the same time?
At that time, will the value of the Period counter be cleared? Or will it be retained?
MPN : CY8C4145AXI-S423
Component : TCPWM_P4_V2_10
Naoaki Morimoto
According to the PWM’s datasheet,
In the PWM modes, the stop event acts as a kill event. A kill or stop event disables PWM output lines.
After killed, line and line_n would turn to disabled and become logic ‘0’.
If Stop signal event is selected as Don’t stop on kill, the counter will continue to count;
If Stop signal event is selected as Stop on kill, the counter will sopped either.
NaMo_1534561
Does anyone have information?
I hope both Line / Line_n become Low output by the KILL signal.
In PSoC 5 LP, when one was Low, the other was high output. How about PSoC41xxS? How about PSoC41xxS?
