hesc_1314511
10 replies posted 10 questions asked 5 replies posted
Dear Sirs,
I have some trouble about circuit are using PSoC 4100M Family.
with power on or when I program, it is difficult to start correctly the CPU.
specifically, when power on cpu does not start correctly, I have to wait many minutes between each power on. I try to short-circuit Vcc, but it's very difficult to restart it.
When I program the CPU, it is difficult to program, a message tells me that the CPU is not recognized. I have to short-circuit Vcc many times, and then I can program.
How can I do? Should I use a CPU hardware reset?
Thank you
Hello Bragadeesh
found the problem in a damaged Cpu not running correctly. I changed it and now it work properly
So many thanks
Henry
Il 16/04/2019 12:25, BragadeeshV_41 ha scritto:
<http://www.cypress.com>
Cypress Developer Community <https://community.cypress.com/?et=watches.email.thread>
About reset of PSoC 4100M Family
reply from BragadeeshV_41<https://community.cypress.com/people/BragadeeshV_41?et=watches.email.thread> in PSoC 4 MCU Community - View the full discussion<https://community.cypress.com/message/193184?et=watches.email.thread#193184>
BragadeeshV
Hi user_297242135​,
Could you please share snapshot of the schematic of your design?
What are you short circuiting VCC with?
Also, make sure that the decoupling capacitors are placed as given in the datasheet.
Bragadeesh
Bragadeesh
Dear Bragadeesh,
please see my schematic
Henry
reply from BragadeeshV_41<https://community.cypress.com/people/BragadeeshV_41?et=watches.email.thread> in PSoC 4 MCU Community - View the full discussion<https://community.cypress.com/message/192764?et=watches.email.thread#192764>
Hi user_297242135​,
Thanks for the update. We don't find anything wrong with the schematic as such.
Please let us know the following:
1. How you are programming your device? Miniprog?
2. Did you try programming using PSoC Programmer?
3. Could you please share the screenshot of the error message?
4. Can you please share screenshot your select debug target window?
4. Could you please let us know the steps to reproduce the issue so that we can try it at our end?
Bragadeesh
Bragadeesh
Hello Bragadeesh
So many thanks
Henry
