noha_3407421
Distributor - TED (Japan)
First like received 10 replies posted 10 questions asked
I inquired about the SWD pin in the following community.
    https://community.cypress.com/message/164808#164808
This is another inquiry about SWD pin processing.
Q1.
Is it OK to keep the SWD pin open?
Q2.
Does the SWD pin have an internal pull-up like the XRES pin?
Harukawa
Vasanth
Hi Noritomo san,
Q1.
Are you asking in cases when SWD is not being used? In that case they act like regular IO pins. . Normally it suggested to keep the unused pins in HighZ mode( which is by default).
Q2.
The SWDIO have internal pull-up and SWDCK will be have an internal pull-down normally when SWD is enabled.
VRS
Bob_Marlowe
Level 10
Level 10
When you do not use the SWD and SDA pins for debugging (having set them to GPIO) they act just like "normal" IO pins. You may (and may not) configure them having internal pullups and other drive modes as shown in the pin's datasheet. When set to GPIO you still can use the pins for programming the device using a programmer.
Bob
Vasanth
Hi Noritomo san,
Q1.
Q2.
VRS
